Yo how do you disable ABS?
cys19
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
I recall reading a quick way is to find the fuse to the ABS system and pull it out.
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
i took out the abs module in my car and replumbed the lines too, i get alot more pedal feel and response now that the fluid doesnt have to go trough the abs unit and of course the weight reduction of the unit is a bonus.
Master_Tao
Car: 93 skyline gts-4
E dogg could you be a little more specific, I was thinking of doing this to my car. And besides the weight bonus why would that be the better option than the fuse?
corn322
Car: 1993 240sx
you could go to a junkyard and find a non-abs 240. take the clutch lines from it. you catch my drift.
ghettoslide
Car: '90 240sx, '91 240sx, '98 DSM, '05 Avalance
You could remove the wheel speed sensor on any one wheel, this will disable the entire abs system and still leave normal braking capability, although it will probably throw a fault code and turn on your mil light.
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
I took out the abs block, master cylinder and lines and replaced it with lines and a master cylinder from a non abs car.
silkk
Car: 94 B13
89 S13
07 S2000
why did you guys take out abs? is it cause of weight?
i wish i had abs in my cars. abs saves your life and your car :)
