Eikon »
https://forums.nicoclub.com/eikon-u15727.html
Tue Nov 14, 2006 6:56 am
My brother's car:93 240sx Convertible. Stock KA24de engine.
Long story.. you can skip to the bottom 1/3 to get the idea and what I'm asking about. Thanks!!!
Bought the car about a year ago with a bad auto trans. Started it once or twice but couldn't drive it around. It sounded like it had a pretty bad timing chain guide rattle. Topped off the oil and the timing chain rattle got better.. but still there.
Let it sit over the winter and through this summer. Engine seemed to be just fine for random startups.
After sitting for a while it developed a miss. Pulled spark plugs to find out it was cyl. 4. Swapped fuel injectors from 4 to 3 and repulled spark plugs... the missed moved to 3... So bad fuel injector.
replaced with new injector and it seemed to run ok. Not great, but wasn't missing anymore.
After 5 spd swap, drove it about 40 miles from shop to home. Seemed to run ok.
Next time it started with a loud rattle (thought timing chain guides again), topped off oil... didn't get better!Started it again a few days later... same loud rattle. This time it started spewing heavy white smoke.
Last night we tried to drive it a few miles to a buddies house to diagnose and compression test it... Didn't make it!!! The car died and is now sitting in a parking lot of a conveneice store.
I can get it to start. But it smokes a ton... like you can't see the cars behind you!! The smoke is white and smells of coolant.. but I don't see oil in the radiator cap.??
Any ideas???Head gasket because it smells of coolant and runs like crap! But I've never seen that much smoke! It's like we seafoamed it!
Timing chain may have slipped a few teath and the valves may have impacted the pistons... That would explain why it runs so bad and bogs down and dies. But would that cause the white smoke?
Any other ideas??
