rb250sx »
https://forums.nicoclub.com/rb250sx-u8777.html
Sat Nov 20, 2004 6:04 am
well, i st arted by checking the voltage at the relay. the signal wire had voltage, and both switched power wires had voltage, but for some reason, the black and yellow wire sending power to the pump only had .2 volts coming out, so i switched the relay and it was the same thing. so finallly i got upset and cut the relay out of the critcuit. now to do this, i just connected the signal wire from the ecu to the black and yellow power wire, but realized there was no voltage accross it(even though there was voltage across the black/pink wire before). so i tested the voltage across the relay again, and for some reason, even though i cut the signal wire there was still voltage going into the relay at the signal wire. So i tested the other half of the black/pink wire where i cut it(the KA side of the wire) and there was voltage across it. So for some reason, the power goign through the signal wire is coming from the KA side of the harness(ignition switch im assuming) not the ecu side, and it seems like it splits somewhere in the harness sending power to the relay, and also sending power to the ecu. So even though this was confusing, i just connected the hot side of the signal wire to the black/yellow wire carrying power to the pump, and still had nothing. so i went back to the plug at the pump and there was voltage there, adn then took the pump out of the tank and checked the voltage across the pump itself, and there was 11.6 volts across the pump. then to check the ground i unplugged the plug at the pump and checked the voltage across the plug, and it was good, so the pump has a good ground and also has power, but it doesnt do a single thing. sorry if most of this is the same as the first post in this thread but i was just trying to answer ur suggestions kuillin_drifer
