SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Sep 18, 2007 4:16 am
The tach wire gets its signal from somewhere in the inner engine harness, CAS area. If you are not getting a signal from the yellow/red wire then there is something wrong with the signal of that wire.
The wire in the picture is on all SR wiring harness' and is used for diagnostic purposes. It is not meant to be the signal for a gauge cluster tach.
1989-1990 tach's do not read the signal of SR's. But the Defi gauge should. Try to find out if the tach signal got cut somewhere on the inner engine harness.
