yet another subframe removal question
fooiimonkey
I searched and havnt came up with the answer on how i would remove the subframe to get the bushings out. is it just bolts holding in place or do i need to remove other things before it will come off.
naed240sx
Car: .....
Just disconnect anything holding it to the car. Obviously the ebrake cables might need to be moved, but other than that it is just he 4 main bolts.
crzycav86
Car: 93 Nissan 240SX KAT
unbolt the calipers and driveshaft.
on the right side, there are a couple of small brackets that need to be unbolted(you will see them when you get under the car... they are attached to one of the main mounting points).
and then there are the 4 main mounting points.
fooiimonkey
thanks guys appriciate the fast responses
rb20det_pwr
Car: skyline hcr32
I set aside the whole day to change mine and was pleasantly surprised when it only took about three hours..And you could do it faster if you wanted to.
Getting it back in you may need to use two jacks unless you have a big floor jack..
zerothread/97924
