forticr »
https://forums.nicoclub.com/forticr-u77054.html
Tue Sep 25, 2007 5:39 pm
So I've recently joined the pathfinder club. After taking it in to Advance Auto, because of the check engine light, I found out I had code P1145. After reading the long history of posts and following my Haynes manual, I switched the left and right bank sensors and brought it back in. Their computer read the same as before two P1145 codes (one of these pending) and a P1140 code.
I figured that the original left sensor was bad and replaced it. Tonight I brought it back in to get cleared and got new codes read. I had it even worse. After replacing the left bank sensor I still have the P1145 code, I also have the P1140 (which will need to be replaced), but now I also have a P1136 code.
I haven't been able to find the P1136 code mentioned in any forum for a Pathfinder. My Haynes manual says its a "Intake Valve Timing Control Solenoid Valve" (left bank).
Is this the solenoid behind the P1145? If so does this explain why my P1145 code is still on after I've replaced it and cleared the codes? Anyone know of a place or site I can get one for a fair price?
