Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Nov 03, 2005 5:59 am
The main problem people have is understanding the exponential graph of the voltage vs air flow.
At idle 0.2 volts [1.2 vs 1.4] is significant at 6,000 rpm WOT [4.2 vs 4.4] is less so.
Hard to mentally get around that x tps voltage and y rpm generates a rough estimate of LOAD and MAF is the fine tuner.
Because you COULD be atop a 12,000 foot mountain [in Summer] or in Death Valley [in winter] the air density could be 30-40% different with the exact same tps and rpm...........thus the MAF voltage would vary.
Just like O2 sensors are the fine tuner at steady rpm cruise..........
