08altima35 »
https://forums.nicoclub.com/08altima35-u83953.html
Sat Dec 22, 2007 9:05 am
I slightly disagree with you a little bit, but am not 100% for certain. The tube coming off the grill is directed right into the new filter so at any kind of speed that cold air is still being blown into your after market intake. And, it's not a jet turbine and you don't really have to worry about engine sucking more air than is readily availible in our atmosphere so... I took that air tube off this morning, but didn't really notice any difference when i wound thru 1st, 2nd, and 3rd gear. It's not really a matter of how much air is availible, but how little restriction there is for that air from the time in enters your filter, goes thru the motor, ignites the fuel (more oxygen, more burn) and goes out your exhaust. There's many things restricting that flow of air from a to z and the more you unrestrict the air the more power you will gain. or you can force feed your car air by means of turbo's, superchargers, and nos
