Megaseth »
https://forums.nicoclub.com/megaseth-u593.html
Tue Feb 10, 2004 4:24 pm
ok, sorry to start another of these, but i just need a quick answer or two. ok, i know the dual altima fans fit, but by fit do they mean fit on the radiator fully or fit as in line up with the mounting points? if not, i guess i'll use zip-ties or some wire.
now to the second, slightly more involved question. as for wiring...how does this sound: dual fans, both grounds going to the frame. the positive wires spliced together, then run to a relay, then from the relay to a 15a fuse and then to the +batt. terminal. then, run a wire from the relay to the ign. and then ground the relay. is that ok? i dont plan on using the thermoswitch till i can get in there and drain the radiator. this is a future mod, but i need to get my fan fixed cause the old one is dead and it sounds like azz. when i wire the relay to the ign, do i just splice it to the ign wire? or part of the harness, or what? thanks for the help, sorry to start another of these.
