johnparkyourcar wrote:Has anyone ever noticed a squeaking sound coming from the brakes? I went to a shop once to find out what it is and the mechanic told me its because my brake pads are worn out and that the squeaking I hear is the sensors. Is that true? I can hear the squeaking sound when I first apply the brakes lightly when coming to a stop. But then again I can also hear the same kind of squeaking when I drive over bumpy surfaces.
Most brake pads have a small piece of metal that points towards the rotor but is only about a third of the thickness of the pad. Once your pad gets that low, you hear the little metal tab scraping against your rotors.
Quote »Hey numb, don't get your hopes up. About 18 months from now, after the warranty runs out, you'll be doing those brakes again. Every 18 months for the life of the car. And Nissan will tell you it's your driving habits. Thank you Nissan. We are in the process of filing in court under California lemon Law statute. The brakes are junk, they can't fix it. I want my money back, and I'm going to get it. Cheers, Larry m [/quote]I'm just as sue happy as the rest of you, but you're funny.
The pads on my I30 last me around 6-8 months which equates to about 10k-20k and I don't make a peep. They cost $65 and take me all of 30 mins to put on.
Quote »I replaced my front brakes for the first time after 38k miles. I went with the OEM brake pads. Supposedly they wear more, but my previous ones lasted 38k miles , so that's not too bad. They squeal once in a while, but it's not a big deal to me. Also, if you want to save money you should have someone resurface your rotors. They can be resurfaced 1-2 times. Resurfacing is a must if you don't want to buy new ones, as the pads will not sit properly. If you don't plan on tracking your car, resurfaced rotors will perform good enough. They should not warp under stop and go driving as someone said above.
When I drove my 200sx, I always went with after market name brands. After I did that for 100k miles +, i decided to check the OEM. The OEM brakes performed much better than any popular name brand performance brakes. Since then I stick with OEM parts. I'm sure those engineers know wtf they are doing.
To sum it up then: go buy OEM pads, have your rotors resurfaced, and replace it yourself. [/quote]What kind of lame performance brakes did you buy that had the same or worse performance?
I have Hawk HPS and Powerslots on my I30 and even with glazed pads and rotors, they stop better than Infiniti brakes do.
