Yet another AC problem
reggiegsd
Car: '94 Q, '73 240Z
The AC in my '94 Q is blowing the fuse. Here is what I have found so far.
The AC clutch checks out fine (draws 2.5 to 3 amps or so).All three relays check out fine (the coils have about 75 ohms).The fuse blows a soon as the car is started. Even with the three relays removed.The load side of the fuse (measured at the fuse block) has a resistance of less than 1 ohm.
It appears I have a short in the wiring loom. Has anyone had this failure? If so, where did you find the short?
