Some questions though that I wanted to ask first:
The heck was Nissan/Datsun thinking with the water channels!?
How common is it for the diffs and transfer case to leak? Everything on the poor gal is leaking something, from some where. When I go to change the seals, is there anything else I should look at or change while I am in there? It also looks like the transmission and the oil plan is leaking slightly.... I figure I would go through and replace the u-joints.. I noticed a vibration around 45-55mph from the rear of the vehicle.
The junkyard has an 86 720 that has a tach and clock that I am going to pull this weekend. I assume it is just a "plug and play" thing or is there any wiring that needs to be done?
I am planning on getting a lot of PB Blaster, Rust-Oleum, etc. Do you guys have any recommendation on using a rubberized undercoating or just stick with the Rust-Oleum?
The day I looked it over
The rear diff leaking
Transfer Case leaking
Front diff leaking
The transmission leaking... or could be the slave cylinder
Oil pan leaking
