Yet another 5 lug conversion question
tdawg88
Car: Vert 240sx
I have read and done a lot of research and am just having doubts about what is needed for the front conversion. I have a complete z32 front and rear hubs. Swapped the rears already and am having complications with the fronts.
SO the question is: can I use the z32 hub for my 240? and if so, is it a process of unbolting the nut in the back and putting it into the s13? or will I need to get the s14 upright which Im not sure which that is. Either way, how much bs do I need to go through for this? Someone help out. THanx
180fan
Car: 89 fastback
You need to search. No you can't use the z32 hubs in the front. Yes you can use the s14 uprights but you'll need to drill out your struts mounting points. If you've looked at the front hub, you'll see there's a large nut holding the hub in, not held in with bolts at the back. Look for pricing. If you don't want to go through all that bs, get some 5 lug conversion hubs.
