...Yet another 240sx problem...fuel?
allenms240
Car: 1991 Nissan 240SX
I've been having some problems on my s13 (No suprise...)1991 240sx KA24DE
Well every now and then, when i start the car, it idles funny, and if i push on the throttle, the car will bog out. I just let it idle bad for about 30secs and i finally fixes itself and no more bad idle. Well yesterday, It did the same thing, only the car died out and didnt want to start again. finally after waiting a while and turning the key to accesories (for the fuel pump) a few times, it started right up without a problem. But today the same thing happened. I tried to even do what i did earlier with the fuel pump, but it didnt work,. i looked at common stuff, (Fuel pump fuse, fuel pressure after the filter etc.) and went to try the car agian. It fired right up.I can;t be driving this thing around with it being unreliable like this o.o and its my daily.
Any ideas?
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
I'd replace the fuel filter and check for a clog in the fuel lines. Have you replaced the fuel pump or is it the original one?Clean your MAF. A dirty one can make an engine bog and die.
allenms240
I recently swapped the motor from shells due to an accident.Fuel filter was replaced back then. How should i go about checking the lines? Think I should just seafoam the gas tank/lines? if the maf was dirty, woudlt it always be acting that way? not on just random startups?Its the fuel pump from the previous shell (OEM one)I hear it prime up when i turn the key to acc, but it could be going out,, right?
allenms240
Bump?
Steady_One_S13
Hook up an inline fuel pressure gauge and check it idle and at wot.Are you getting any codes?Good idea on the Seafoam, but it'd best to replace that fuel pump.
allenms240
Wot? The CEL Isn't on so no codes. What about the fpr? What does that do, I'm unfamiliar with what it does
Steady_One_S13
wide open throttle
Fpr is like a valve that allows a certain pressure to be maintained inside the rail.Something like that. Chances are your fpr and fuel pump is old and fatigue. Get it replaced if it hasn't ever been done so.
allenms240
Yeah that's what all my friends were thinkng. I was trying to leave Dunkin Dougnuts when it acted up again. They think its fuel pressure regulator or the pump. Just as i thought. Should I might as well be buying a Walboro 255?Could the ECU be going out?Because I don't understand why after a while of trying over and over to oget the car on, it will finally just start as if there were no problems.I'll end up replacing the pump, and seafoaming the gas tank. And if it still exists, try the FPR, and then the test the ECU with a friends, Sound good?
Steady_One_S13
ecu... no...but test it anyway.walbro nismo fpr
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
Check the ECU for codes. Clean the IACV that could be your problem.
allenms240
Solved.Replaced fuel pump with a spare one I luckily found.I haven't had the startup problem since I put it on yesterday, and the car pulls ALOT faster than before. Runs stellar. I'm guessing it was the pump for two reasons:Havent had the problem sinceAnd the motor has more power(more fuel)The other one must had be dying out.Thanks for all the input guys. )
