Justinians_2:40 »
https://forums.nicoclub.com/justinians-2-40-u122224.html
Tue Oct 26, 2010 11:03 am
As far as your oil weight choice, if it gets that hot, I suppose I could see using a 50 weight (we usually stick to a 40 even in our turbocharged Formula SAE car and that seams to be heavy enough for us, even in high heat), but whether it's a 10w or 15w won't matter too much, that's just the weight of the oil when it's really cold, almost right after you start it, it will warm up enough for that not to matter. Also, with that high of heat, synthetic will hold true to it's rated weight much better for much longer. Conventional oils breakdown pretty rapidly at those high temps, both due to the fact that they're conventional and the fact that the additives to make it thinner at low temps, for starting, also have a negative effect on the oil at high temps. Basically, synthetics are much more consistent through out the temp range.
To address KA24JEF's comment about the synthetic oil causing smoke due to cleaning, whatever contaminants are cleaned out of the system will be caught in the oil filter. If you're experiencing smoke, that means the only thing keeping oil out of your combustion chamber was either carbon deposits on your valve seals or carbon deposits on the piston/piston rings. Now that those carbon deposits have been cleaned away, you'll get oil leaking into the combustion chamber, burning up and causing a blue smoke. If this is the case, the problem is not your oil, but the motor itself. Seafoam only smokes when it is ran into the combustion chamber via the intake or fuel, otherwise, if you get smoke or bad compression afterwards, it's for the same reason as the oil.
Sorry for the long post, I was thinking about this in class and just wanted to be able to provide the most info I can.
