Yes i know, another z32 brake question...
WhiteChukiS13
Car: 2004 Infiniti G35 6MT
I am upgrading my brakes but i am retaining 4 lugs. I am going with z32 30mm calipers and rotors. From what i understand the calipers bolt right up on the front. A write up i read threw me of though, i didnt understand the way he wrote it about the rear install, he didnt explain if the caliper bolted right up in the rear like the front, he went on and did a 5 lug conversion. anyways. help is needed! thanks guys.
kamikazestorm420
WhiteChukiS13 wrote:I am upgrading my brakes but i am retaining 4 lugs. I am going with z32 30mm calipers and rotors. From what i understand the calipers bolt right up on the front. A write up i read threw me of though, i didnt understand the way he wrote it about the rear install, he didnt explain if the caliper bolted right up in the rear like the front, he went on and did a 5 lug conversion. anyways. help is needed! thanks guys.
the rears do bolt right up. you would have to redrill your rotors to 4 lug tho.
but the only problem with the rear is, if you dont use the z32 drum brake you will not have a parking brake.
NoOneBetter
dumb question will stock S13 SE wheels clear Z32 calipers?
kamikazestorm420
the 30mm ones will not clear
