Yellow Key Light Blinking no Ignition
General discussion area for the L32-chassis Altima
RogerGA
Car: 2009 Nissan Altima 130k miles
I recently had the Yellow Key Light Blinking and the well known ESCL failure . Looking at lots of suggestions i managed to get the car to start by disengaging the Tilt Steering Lever and moving the steering wheel up and down vigorously .
I then took the car to the dealer who says there is no OBD code on the car and the car isnt showing the symptoms (I obviously Tilted the steering hard to make it work)
Is there some history maintained on the OBD - if yes how does one access it to prove that the fault indeed occur .?
Can a dealer erase the code or history ?
Also if you have faced the same issue do sign the petition
https://www.change.org/petitions/nissan ... tem#invite
Thanks in Advance
gingi801
Car: 2009 Nissan Altima 2.5 S
Hello, im not sure if the data is completely saved to the point it can be earased, I know that the warranty for the part that is failing has been extended. I would wait till it happed again and have it towed to nissan and have them change the part for free. It can also be your ikey that is probably giving you problems. Keep it away from your phone....
RogerGA
Thanks gingi801 - from the research I have done here is what I know.
A) For this specific problem - it does not log an OBD code
B) The official diagnosis document - indicates a procedure to check if the lock is in open state or closed state by hooking the OBD to a diagnostic interface.
C) For all those who are faced with this condition - it is best to tow it to NISSAN if possible
If you are currently viewing this thread because you have the problem and do not want to tow try this
http://www.youtube.com/watch?v=tADcGlKNtxM
this worked for me .. but take a video of your situation and all what you do to get your ignition back , This will be the only proof you have to show your dealer :)
gingi801
RogerGA wrote:Thanks gingi801 - from the research I have done here is what I know.
Thats a great, you learn something new every day ;-)
Return to “4th Generation Altima Sedan (2007-2012)”
