Yellow HID's
turbo6
Car: '05 350Z Turbo, '98 SC300 9.3@156, '99 SC400, '02 Police Interceptor
Where can I get them?
Mr1der
don't please, they hurt my eyes!:D
I prefer the blue, they don't seem as brutal on the ol retina...
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
if u notice, all those cars with yellow lighting have yellow lenses too...
-Dan
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Good eye.
I have no idea about any HIDs other than the blueish ones.
NY94J30
Car: 2000 Q45 AE
My bet is theyre not DOT approved
silkk
Car: 94 B13
89 S13
07 S2000
i like the purple-blueish ones you see on bmws
BB Turbo
Car: 2007 Nissan Titan KC
1992 Nissan 240SX Coupe
The yellow looks dirty. Sorry no help here.
leohj
Car: Basketball, S13, S14,S15
silkk wrote:i like the purple-blueish ones you see on bmws
i like them too.. they look sexy haha :D
MrEous
Usually with HIDs the higher in rating you go the more blue/purple they get.
4300k HID looks the most white8000k HID looks purplish
maybe lower HID ratings would be a yellowish color...
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
#k refers to the temperature of the light. White light (which is really what you want when you're using hid) is in the lower k range (~4300 as prior posted). Blue light, which doesn't go as far, but looks much much prettier is up in the high temp range (as pointed out above). I'm pretty sure what you're seeing are white hid's with the yellow cover over them, which makes them look yellow. Why do it? I don't know...
edit: to tell you the truth, those yellow hids remind me of my old neon green legos that had edge glo. Those were the hottness...
Dattebayo
Ive worked on wall mounted HID fixtures, like the kind u see on the side of your apartment building. From what ive seen, the low temp low pressure sodium fixtures glow orangey-yellow, and they only get to around 1500K degrees.
So i think that theory about the yellow ones might be valid.
But then again, it also depends on what kind of gas you are using inside the discharge bubble (there are no filaments in HID).
Does anyone know what gas is in their HID's on their cars?
dplxy
i saw a yellow HIDed civic got pulled over last weekend, he was behind he and im sure ho got HID, not piaa
btw if u can, get philips 6000K HID kit u can really c the road with that kik and cops will think those r stock HID
spec-u-later
Car: Yaris...FML
White HID with yellow tinted glass (or in most cases plastic), or whatever color you want.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
How about a nice Periwinkle color?
Dattebayo
Metal-halide HID lamps burn light blue.Mercury-vapor HID lamps burn slightly blue, mostly white.High pressure Sodium HID bulbs burn Yellow.Low pressure Sodium HID bulbs burn Orangey-yellow.
I think this proves that you dont need a lens to decide what color you want. A lens would just trap or restrict heat flow out of the fixture and limit the life of your bulb.
C-Kwik
http://faq.auto.light.tripod.com/hl-hid-bulbs.htm
http://faq.auto.light.tripod.c...t.doc
These are just some interesting articles I found.
As far as the types of HID, automotive applications use Metal Halide HID's because of their quick start-up times. The other types takes up to several minutes before they can produce any effective lighting.
To make an effective yellow HID light, I might consider the use of a Dichroic filter. A yellow pass filter would work well here. Dichroic filters are different than tinted lenses in that instead of tinting the colors, it just traps a certain range of colors of light. In the case of a yellow pass, it essentially just traps the blue light in. This is the same way some of the halogen aftermarket fog lights make fore such bright yellow colors(PIAA, CATZ). Depending on what they coat with the filter(lens or bulb) you'll notice a bluish irridium color. You see blue in this instance as the blue light that hits it from the outside is being reflected back at you. This is probably the most efficient way to get a yellow HID look and has the fewest drawbacks. But I'm not automotive lighting expert, so I am not sure what other problems, if any, this might have.
