YEAH! I got all 4 cyl's working!
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
first off, thx dee.. the ecu did the trick. I know what i did now.. i wired #2 injector wrong before, and musta fried the terminal inside the ecu. So, it works now.
Anyway, i drive not even 3 blocks... hit a lil boost... and blow one of my cooler pipes! it falls under the car, gets run over... i then drive back the 50 or so feet to my house with the mafe not hooked up and a boost leak. i figure i ran stupid rich, and flooded it.. now it wont start.Ill try again in the am.
But all my electrical issues are fixed now. only real problem i noticed... i need new engine mounts. the motor bucks like a whore.
ALSO! i need some good 2.5in pipes. i got a cheap set from ebay cause i needed something right away. so if anyone can point me in the right direction... remember i need custom pipes for my pulsar.
THX ALL!!!
float_6969
Congrats! Pix or
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
ryan, what a contribution, you steed you.
anywho, you can always do what i did and use mandrel bent exhaust tubing from auto zone, and plumbing fixtures from home depot. also, i kept having the hot pipe jump off on me under high boost (where it connects to the pipe going to the fmic). no clamp would do because of how well lubricated it was from blow-by, so i gorilla glued the bastard. problem solved.
Liquid_Neon
go
r34 gtr wrote:ryan, what a contribution, you steed you.
GOOD IDEA!GM makes glue for there supercharged vehicles so they dont blow pipes off, since i work at GM i might get a bottle for myself.I gotta fix the oil return line though, its leaking pretty good.
boost_boy
Congratulations on solving one problem, but the motor mount thing can be annoying as well. As one suggested here, you can fill in the webs of the nissan mounts with window weld or you can go buy some urethane and fill the webs as well (if the mounts aren't torn or badly worn).
Dee
nismoplsr
Sweet dude!
Like Boostboy said. Just fill the mounts, its amazing the difference.
Im looking forward to meeting up and cruising with you this summer!
As far as your charge plumbing goes. I dont know what you mean by them being cheap ebay stuff? Round tubing is round tubing. Just get some good clamps if you are using worm gear ones get a bunch of T-bolt clamps and crank them down. After that you should be good to go.
r34 gtr
yeah, gorilla glue is fantasic but i know its never coming apart again, even when i need it to. i would only do it if you are okay with that idea.
Liquid_Neon
nismoplsr wrote:Sweet dude!
I dunno how to get pix on the thread itself. And my digicam i think is dying.. so if u wanna see some crappy pics, u can see myspace, its in a couple pics there.
http://viewmorepics.myspace.co...73075
Also, i dunt know how many times im gonna have to change the oil. There is a lot of fuel from in the oil from haveing quite a few 'crank, no starts' I kinda got myself hi draining my oil tonite
I will play with my cas some until it idles better. fix my air leaks, some oil leaks, and other general stuff after letting my car sit for almost a year!Thx anyone and everyone who offered advice and maybe shared a cheap laugh at my expense.
