Yayyy!
PalmerWMD
Car: 2004 350Z
Just got new struts all around on the Q and new upper links up front.
A world of difference, car feels solid again!
Yayy!
Fred..:fruit
rover3l
Car: 1998 Q45, 2000Q45 Anniversary, 1965 Rover 3L,
Can you describe how the suspension in this new condition react to bumps in terms of feel and noise?
PalmerWMD
Car: 2004 350Z
no more squeeks, steering feel is soldi and more direct.More buttoned down.
Entire car feels solid on the road like a new car.Of course my car is lowered to begin with and the new struts are Blues all around ,to complement the Eibachs.
Also have a new Tstat and my coolant gauge seems to behave just
Fred...:)
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
Nice.Nothing like a good tight ride.;)
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I was also amazed how well the car felt after my suspension was revamped..... Before the car felt like it was floating (when it wasnt bouncing)..... Now it feels like the car is on rails and firmly planted on the ground......
Im sure with those 17s on the front with sticky tires its nearly unbeatable!
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Very nice, now go hit those on-off ramps with eloquence & courage, Sir!
Altiman94
Car: 1989 Nissan 240SX
I have gr-2's on my 240. Would liek stiffer though. AGX"s will be my next set/
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Altiman, consider the Koni's & they'll be the last set you'll ever (have) to buy.
Their lifetime warranty is no joke, had a set warranted after 12 years of abuse with only producing a receipt & my registration to prove I still own the car.
KYB AGX & Tokico Blue's...........one year.
If only Lee Grimes (Motorsport Director at Koni) would consider tooling up even a Red strut for the Q's...................
Of course the strut bodies on the Q are too small diameter to incorporate a Yellow (adjustable) just like the Sentra/200SX........ dammit.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Fred, that is great! I got Blue's from the wife, for Christmas. I have not bought the upper links, yet, but I do have new Tension Rods.
I might spring for the new upper links. Haven't decided, yet. I have put 72,000 miles on the car, in the last 17 months.
The steering feels quite solid, but the car "floats like a butterfly".
elwesso
2007 BMW M Coupe
You can always do links later.... They only take about 15mins to replace once the tire is off.....
Altiman94
are the koni's adjustable. I want the adjustability thats why i was thinking agx
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Altiman, yes, they are, go to koni-na.com for more info. The fronts are inserts (more labor to install) but well worth it.
The relationship between the AGX's & the GAB Super HP's is not what they eluded to. (KYB produced the GAB's under private label, but the AGX was not built to the same specs)
I've had Koni's on every car I've owned in the last 20 years, never bought a single unit twice. ;)
QuickSilver
Fred,
How old (miles and years) were your old struts? They weren't orginal were they?
Heavyduty's comment about the blues lasting a year is not very encouraging. Shouldn't they last more like 2-3years or 30-40k miles?
PalmerWMD
Car: 2004 350Z
I think they last longer than a year but keep in mind that they are often paired with lowering springs which wear shocks out quicker.
I think mine were 3 years old but included extremely hard driving on track running 500+hp Most of my handling improvement I credit to the new upper links actually.
Fred..:)
rover3l
Although I understand the handling is greatly improved by the suspension parts replacement I would like to understand how a Q45 is supposed to sound when travelling over bumps and pot holes. Certain cars like Jag's for example are very quiet even when the wheels fall into a fairly large pot hole.
My active Q is very comfortable but tends to crash when a wheel hits a pot hole and the back end is rattly when going over semi rough road. As mentioned in other posts I am thinking of replacing the usual suspect parts such as upper links, tension rods and various bushings but it would be nice to know how a pristine Q actually behaves in terms of suspension noise over bumps?
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
My one year comment was warranty, not life of the unit. Lowering springs reduce a shock's lifespan, but usually not much more than 1/3 that of a stock spring.
I like the look of my Pro-Kits, but enjoyed the stock spring ride much more.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
rover3l, maybe it's time to look at the other accumulators also.
No rattles or crashes with a conventionally sprung Q45, unless you are doing Dukes of Hazzard kind of nonsense.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Mine clunks a bit, on harsh bumps. When it gets below freezing, the upperlinks get noisy.
New struts, tension rods, accumulators, and upperlinks are waiting to be installed. I am sure this will tighten up things, a bit.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You have an active, Jeff? 180K with so little maintenance of the struts is impressive.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
maxnix wrote:You have an active, Jeff? 180K with so little maintenance of the struts is impressive.[/color]
Sorry, not the accumulators, I was thinking about the strut boots and all the bushings for the strut replacement. I typed accumulators. I've been working way too long, today.
It is a Std, non-active. Although, I would like to get my hands on an active rear stabilizer bar...
Jeff - You're welcome to my 15.9mm rear bar when I pull it off.
Shipping + some beer $$$?
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
AZhitman wrote:Jeff - You're welcome to my 15.9mm rear bar when I pull it off.
SOLD!
Whenever you are ready!:ylsuper
