yay or nay?
nstabl
Car: 1989 Nissan 240sx
this intake came with my car, i swapped it with the stock airbox, then just recently put this back in.... my car isn't running great anymore..
edit: cant get the stupid pic to work.. link: http://img525.imageshack.us/my...2.jpg
Modified by nstabl at 5:36 PM 12/16/2008
Modified by nstabl at 6:02 PM 12/16/2008
Crazyirish
Car: Nothing noteworthy at the moment...
No picture...
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Edit....can't see your pic.
nstabl
bump for fixed pic.. sorry!
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
you check if your MAF is clean?
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
try cleanin that filter then use it, but only once it is dry.
SirSilvia
Car: Sold both my babies
see how that MAF harness is up against that reservoir (or whatever that is) it could have worn and broken the wire/connector.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
i say nay, go back to stock, and use a drop in filter
nstabl
You think the car will run better??
Coolwhip wrote:i say nay, go back to stock, and use a drop in filter
Coolwhip
Vendor
if it was running fine, then you swapped the filter to stock, then swapped it back and it ran like crap... then it must be:
A) You forgot to hook something upB) the MAF has a leak behind it (clamp not tight enough, etc.C) Bad wiring or connection. Turn the car on, and wiggle the harness and plug to the MAF, see if you get a change in performance.
slipknot555_666_69
Car: 97 nissan 240sx
get the right adapter for the filter, make sure everything isnt leaking and it should be fine
tramp_drift240
Car: 1992 240sx SE Coupe
yeah, it really depends on what your car is doing. like, how is it running, specifically, now that that little cone filter is in there.
S13Teddy
Car: R32 Skyline, S13
That air filter gives you at least more 50bhp. Keep it on so you can smoke Hondas.
BallzDeep1.9L
Car: '02 WRX Wagon: SOLD
'93 240SX Coupe: SOLD
'11 Ram: SOLD
'11 F-150: rotted into oblivion
'17 Frontier: Basic AF
S13Teddy wrote:That air filter gives you at least more 50bhp. Keep it on so you can smoke Hondas.
im with teddy, smoking CRX HF's means your **** is damn fast yo....
1rst240sx
Car: 1989 Nissan 240SX
Nay
I say go back to stock , modify the bottom of the box (air) and drop in a k&n . I can take pic later if request but works awesome and Im still diggin the sound improvement
i240sx
Car: 240sx coupe
ziptie will give you massive downforce..
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
I say nay. Get yourself a Sr20 with an Apex i filter or you can clean the filter and MAF.
AutoShadow
Car: 1993 Nissan 240sx
1rst240sx wrote:Nay I say go back to stock , modify the bottom of the box (air) and drop in a k&n . I can take pic later if request but works awesome and Im still diggin the sound improvement
Picture Requested, thanks in advance.
thompson13
get a real; intake
BallzDeep1.9L
'11 Ram: SOLD
if you are gonna spend money on a filter i wouldnt waste it on a K&N though, ive seen WAY to many dyno runs where the stock drop in made more then a K&N cone filter.... just my 2 cents though....
