Wow, so it has been an incredibly long time since I have updated or even worked on the car. Well I finally came home this weekend from school to mess with it some more. I discovered awhile back that my dumbass self grounded out the main power wire from the alternator, the one that is supposed to go to the fuse box. Which is why it died on me initially. God, all of this happened because of a wrongly placed wire!! Learned my lesson.
Anyways, I came home this weekend and took apart the lower harness looking for a short anywhere in there, and all was ok. I also put a rebuilt alternator on the car as I figured my current one was toast seeing as the car was running at 12.1 volts. Thanks to RawBrokerage for that! Put the lower harness back on with the new alternator, connected the wires to the right locations this time and changed out the oil as she had been sitting for a long time. I cranked her up and she ran just as ****ty as before. Exactly like in the vid I posted awhile back...
http://www.youtube.com/watch?v=Ba_P7ultoDY. Still misfiring and running like poo, except now the car is running at the correct voltage (14.4). Tach still didn't work as well. I'll state again that it did work previous to all this happening.
I then took out all the spark plugs and it looks like 1,2,5 & 6 are not firing. Everyone one of them was wet and smelled strong, and the opposite could be said for 3 and 4. Running on 2 cylinders FTL. So I'm thinking that maybe the coilpacks or ignitor got fried in the process. What do you guys think? I need to test the coilpacks and ignitor, can someone explain how to do this or post up a link please.
I'm praying that nothing else got damaged and that I didn't glaze the cylinder walls with all the excess gas. Thanks once again.
