squeefoo »
https://forums.nicoclub.com/squeefoo-u8899.html
Tue Jun 29, 2004 6:56 pm
Wes - all new fluids 2X, drive belts, stereo,fuel pump, pump controller, timing guides,reseal cam covers, had the plenum off5X for injectors, det sensors, leaking fuelpress. reg., waterpump, thermostat, temp. sensor, all new hoses, new plastic fan, master cylinder, 3oozx rotors, SSbrakelines, upper links, kingpin bearings, lowerballjoints, torquearmbushings, remote oil filter, 93TCU, trans cooler, trans mount, OX sensors, throttle pos. sensor, trans. sensor thats a total***** to get to, 4X Tokicoblues (all w/new rubber), rear sway bar, window regulator, rear doorlock actuator, new cluster lens,CLIMATE CONTROL, bead blast and repaint all the rims (peeling paint), FSTB, moonroof probs., fix rotten exh. bands, this just off the top of my head and you may note the only real upgrades are the brakes, rear bar, FSTB, 93 TCU and of course stereo (those five were easy)all the rest just to get it working right. Many many hours and waiting for more. It sounds like there's nothing left to go wrong, but I'm not holding my breath.
