Yaay! got my Greddy oil pan!
PalmerWMD
Car: 2004 350Z
Yayy got my Greddy opilpan from optionimports just now.5 quart capacity and its baffled..http://optionimports.com/grbigoilpanu.html
Just thought I'd share.
Fred..:fruit
jdmfreak
Nice Fred. When ya gonna instal it?
PalmerWMD
Car: 2004 350Z
jdmfreak03 wrote:Nice Fred. When ya gonna instal it?
As soon as I get my Nismo 1.5way LSD from http://www.underground-motorsports.com/home.htm
Fred..:)
PS: Both are sposnors of course and yes I pay the same price as all other NICO members..:angel:
UsedToOwn240SX
Car: Radio Control Racing, Counterstrike
Great to hear that, Fred. Just one word of caution: don't overtighten the drain bolt. I stripped mine already. Had to take it all off, retap with bigger bolt.
PalmerWMD
Car: 2004 350Z
Used:Thanks for the tip!So a basic gentle handtighting?
Fred...:)
UsedToOwn240SX
Yup, unfortunately greddy doesn't say how much torque to be applied. When I stripped it, I tightened it to the torque mentioned in the S14 SR manual (around 25 ft-lb). Apparently that's too strong. Now I use a nylon washer in place of the crushable Nissan washer.
jdmfreak
Wow Fred. That Megan package is such a good deal. I wish I had a 240.
Phax
Car: Control dynamics
UsedToOwn240SX wrote:Great to hear that, Fred. Just one word of caution: don't overtighten the drain bolt. I stripped mine already. Had to take it all off, retap with bigger bolt.
:Werd
I was intentionally gentle with mine as well and ended up stripping it. $!#$% aluminum !@#$!
Nice upgrade. How long were you running around with the stock pan for? I got my oilpan right after the head gasket. I was scared to run around with the 2-3 quarts that the stock pan holds.
Nismo_Freak
Car: 89 Nissan 240SX
UsedToOwn240SX wrote:S14 SR manual (around 25 ft-lb)
Steel pan to aluminum is 6 lb. ft.
Fred even hand tightening the bolt could make it over tight. Apply liberal amounts of the silicone sealant and put very little pressure on the bolts when they go back in. Tighten them in a criss-cross pattern.
VitaminT
Car: 93 240sx SE
I think they are talking about the drain plug not the mounting cap-head bolts.
Dori Dori
Car: Cars of course
jdmfreak03 wrote:Wow Fred. That Megan package is such a good deal. I wish I had a 240.
The muffler looks like poo though...the pipe coming out of the canister is like 30ft long. :P
Hijacker
Car: '92 240sx Convertible
'94 F-150
Phax wrote:Nice upgrade. How long were you running around with the stock pan for? I got my oilpan right after the head gasket. I was scared to run around with the 2-3 quarts that the stock pan holds.
the block holds 3.5 quarts. I usually end up putting 4 quarts in. That's the average amount of oil needed for a 2.0l block. So, I don't see why you're scared of 3 quarts of oil?
Def
Car: Cars, Engineering Stuffs
Because 3 qts of oil doesn't have very much heat capacity. It is easy to get such a small quantity of oil to its thermal breakdown point with just short bursts of hard driving.
My M3 uses 7 qts of oil for comparison, and man it makes for some expensive oil changes with Mobil 1!
