Recently (past month), it's gotten much worse, occasionally stalling entirely at idle, and making it a gas hog to drive because I have to keep it revved whenever im at a light.
What have I tried? I've cleaned the air filter (one of them re-usable joints), and started putting 93 octane in it again (it had been running mostly 87 for a year or so). Searched visually for vacuum leaks, no luck. Ran the ECU diagnostic twice, first time it came up with "fuel injector leak" (!). Second time it came up all okay (55). Visual inspection reveals no external injector leakage...still suspicious of fuel injectors though, so I bought a pressure gauge and, for the heck of it, decided to seafoam the engine first. 1/3 to fuel tank, 1/3 into vacuum. Guess what? PROBLEM FIXED...for about a week...which is about the time I filled the tank again. CLUE?
I'm going to check the fuel pressure this weekend unless someone here can figure out what it might be, based on this. I've searched of course, and while stalling is not exactly an uncommon problem, I think the seafoam-fix is a clue, so I'm posting this in case one of you knows what the clue points to. I sure don't.
Thanks friends. I will keep this updated if I learn anything.
