Just in case anyone cares...
REPLACEMENT BANJO BOLTS:
-If your car came non-Akebono calipers equipped from the factory and you want to upgrade to the Akebono calipers, you can retain your stock rubber brake lines and get (4) banjo bolts that will bolt right up to the Akebono calipers. This is the easiest route to go since you don't need to unbolt your stock lines. You just simply swap out the old banjo bolts (will not work Akebono calipers) with the replacement ones that are the proper length to work with the Akebono calipers. Shoutout to Nick from conceptzperformance.com for getting the banjo bolts here in time.
https://conceptzperformance.com/technaf ... _13378.php
STOPTECH STAINLESS STEEL LINES:
-StopTech stainless steel brake lines is another option for everyone that wants to upgrade their brake lines. I can confirm that the rear lines will work without any issues. As for the front StopTech lines you may need to get creative on routing the brake lines since its a bit shorter than the stock lines but i think there is enough length to make it work. I'm on the fence about buying a set and mounting them, until then I can't confirm the front lines for sure because this set was intended for the G37S. Michael from TunerzStore says they will fit since they sell this kit to their M37 and M56 customers. This kit will include all the lines and hardware needed to swap out the oem brake lines set.
Front Centric # 95042012
Rear Centric # 95042503
GOODRIDGE BRAKE LINES:
Part #: 22039
This is the only kit on the market that is made to fit the Y51. This upgrade kit is perfect for anyone
that has a factory equipped Akebono calipers. This kit will upgrade their all their rubber hoses to stainless steel but it
does not include the brake tubes that completes the connection from the brake lines to the Akebono caliper. This is a huge issue for anyone like myself that did not come with the factory equipped Akebono calipers. I'm not sure why Goodridge doesn't include everything that is needed, right now I am in the debating if I should pay an extra $70+ for oem brake tubes to get this kit to work with my car.
Again if your car came with the Akebono calipers from the factory it will already have the brake tubes needed to make this Goodridge kit to work.
