The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Wed Apr 20, 2011 5:15 pm
Blanco, regarding asterisks and their layout, I only mentioned it in case someone else could later point out that it was somehow relevant. If I was trying to complicate things, I would have pointed out how awesome 400 miles per gallon would be, but I know you meant tank.
Anyway, the analog signal from the sending unit is converted to digital, and probably not really converted back to analog even for the analog dial, but the digital signal is used by the computer, which could easily be programmed to treat any given digital point as 0/E. Regarding the M45 that ran out of gas and only filled up around 18 gallons, you are aware of our tank filling issue, right? Infiniti would typically only cover it under warranty if you consistently had significant trouble filling up beyond half or three-quarters full, and often pointed out how it depended what pump you were using and wasn't necessarily the cars problem. I got that fix, and it's still difficult to actually get my car completely filled. The M45 Mexillis knows about may or may not have had that TSB performed, may or may not have pumped full blast without verifying the tank was full afterwards, may or may not have been parked on an incline that affected the amount of gas that could go into the tank, and may or may not have been affected by any other number of mitigating factors (for instance, did the car get towed, or did a service person provide 2 gallons that weren't counted to drive to the nearest station?). Regardless, suppose Nissan did screw up ALL of their documentation regarding the tank size on our car, do you really think they would just let it slide and not release any kind of statement or amended information regarding that?
