EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Sun Jan 15, 2017 10:18 pm
Like Gene said, the 03 trans will upshift for you at some RPM even when you have it in manual. The 04 behaves like the 06+ trans. Say you have it in manual mode and come to a stop, it drops down to 1st and holds it there until you bump the rev limiter at 50mph on the highway. Coming from an 03, that surprised me a little.
So, about those production dates I'm not sure whether they are referring to the transmission or car assembly. Because cars thru 10/02 are actually 2002 model years and maybe very little of 2003...so that will mostly seem like 2002 Q45 models.
Best bet in this situation is to call a dealer with your VIN and they'll tell you exactly which part number applies to you.
Even IF it's just a programming difference, the dealer will most likely still try to get you to buy the "correct" one. I'm a little adventurous and I'd use whichever one I can find easier/cheaper.
