Double E »
https://forums.nicoclub.com/double-e-u86689.html
Mon Jul 06, 2015 12:26 pm
No issues with making anything wear faster or pass inspections without them...but flex is exactly what they do, and that's it. No flex means something else is going to give when the engine moves on the mounts...and it does.
Before you proceed further, be sure you get under it to view the proximity of the flex pipes to both manifolds and converters. I do not think there is a reasonable to way to make anything close to an x-pipe on this car based on the OEM configuration.
A manifold connects to the bank which is followed by the primary cats, then flexpipe...and that's before they even get to the transmission. After that, they come together into one pipe, the secondary cat and then the resonator, then to the muffler where they split back up again and go to a butterfly valve that (we all think) is for noise reduction....
I think you're better off to remove the resonator and put in an exhaust cutout with remote control.
At least it will sound better.
