szh »
https://forums.nicoclub.com/szh-u149.html
Thu Mar 13, 2008 6:17 pm
I have a 2003 M45 with the stock 18 x 7.5 wheels and am running 245/45-18 tires (a teensy bit bigger than stock).
This morning, I was checking to see how to install tire chains if I needed it (am in Lake Tahoe right now) and noted that the clearance in the front tire to suspension components makes it impossible to put chains on the front (I wanted to do all four wheels if I needed it) - even the slim spring cable ones from SCC (model 1040). The back was fine!
In fact, with an offset of 40mm (for a 8.0 or 8.5" wheel), I think the tire might/will make contact with the suspension component that is in the way. I would definitely pick 35mm or a bit less - although too small would put the tire under the fender too much!
Like I have said before, the new 2006+ M wheels - Sport or otherwise (the offset is almost 50mm) are definitely not possible for sure without spacers and spacers are evil!
Frankly, with the current stock wheel and offset, and 245/45-18 tires, I think it fills out the well perfectly. No change needed for me!
Z
