y33 windshield washer spray not working
Qproject
nozzles are clean, not clogged.
looks like there's water in the windshield washer reservoir.
what could be the problem ?
captainluigi
Car: 1996 q45t
Owning a G50 i'm not sure this will help but i'll try. Check fuse, check pump. Do you have a DVM?
SUB ZERO CAR FANATIC
Car: 1993 Infiniti Q45 ( SOLD)
1997 Cadillac Deville Concourse
1998 Cadillac Seville STS
2009 Infiniti QX56 LE
I would say its your washer fluid pump. Do you here a humming type noise when you press the button to make the washer fluid spray, if you dont,i would say 95% its your pump.Look under passenger side fender well under the plastic toward front bumper area of inner wheel well you will seethe white plastic bottle,blueish if you have blue washer fluid in it, have someone hit the spray button if you dont get any noise or anything when you touch bottom of resevoir where pump is,thats your problem,after you have checked your fuse panel of course and ruled out bad fuse.Good luck, hope this helps!
SUBZERO CAR FANATIC
OOPS!! I thought you owned a G50 not a Y33,im sorry. I would still say the exact same thing,just not sure of your washer fluid resevoir location, might be the same as G50, not sure!!
