Y33 Wheel Fitment question
gccustoms
Car: 1998 Q45t
Can anyone tell me if this set up will work for my 98 Q45T MERCHANDISE WILL FIT ANY 2003-2006: NISSAN 350-Z AND INFINITY G-35 WHEEL SIZE: 19 X 8.5 (FRONT) 19 X 9.5 (BACK) 5 LUGS OFFSET: 15mm (FRONT) 22mm (BACK) BOLT PATTERN: 5 X 4.5 FINISH: BLACK BRAND NEW TIRES: Hankook Ventus K-104 SIZE: 245-35-19 (FRONT) 265-30-19 (BACK)
Any help would be much appreciated
Falkdesigns
Car: 1998 Q45t ~ EXE
Sizes and offsets are fine. Should fit fairly flush to the fenders. They need to learn how to spell INFINITI though. What wheels are they?
gccustoms
Car: 1998 Q45t
That is great thanks for the help. I have been reading all the posts for 2 months now and it is time for me to get my Q in shape The wheels are on ebay here is the item # 280033001295 Falkdesigns please give me your opinion Your ride is Wicked Oh any thoughts on where I can get some Eibachs I am concerned about alignment problems with the Tein springs
Falkdesigns
There are no alignment problems with Teins. The only issues anyone has had were noises, but from what seems to be the consensus now, the noises are from either Tension rods, or Strut mounts, or both. Eibachs are discontinued.
Not bad looking wheels, you might want to check Memoryfab.com and see what used JDM wheels they have in that price range though. If you get those on eBay, I'd paint the center caps black, and get some die-cut Infiniti logos to stick on them.
gccustoms
Car: 1998 Q45t
Do you know of anyone with some used Eibachs I will check out the website right now Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Falkdesigns wrote:There are no alignment problems with Teins. The only issues anyone has had were noises, but from what seems to be the consensus now, the noises are from either Tension rods, or Strut mounts, or both. Eibachs are discontinued.
Just be warned that you should probably get an alignment after doing the springs because TOE will be way off where it should be... Extra camber doesnt bother is us as much as extra toe does.
Falkdesigns
Oh you should definitely get an alignment, but there should be no problems other than being a little past factory specs on camber only.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
You are not going to find any Eibachs so you should just drop that idea. You either go Teins or stay with stock, I did the Teins with no issues, regrets or problems, got them from Kevin. The Eibachs are gone for years now and frankly no big issues with the Teins save some people with bad installs.
Rex
Car: None
As others have said, the sizes you listed will fit fine, not sunken like stock, but not so "outward" as to require any "fender work".
An alignment should be performed after any suspension work, but isn't impossible after lowering the car (within reason ).
As for wheels, those are okay, but there are alot of good/better options near that price range. I realize those come with (new) tires, but they're not high dollar tires, so price up some other options and keep your eyes open. Used G35 (forged) 19" staggered take offs with low mile tires can be had for that price. And though they wouldn't be as flush are such a better wheel/tire set up.
qship96
Car: 1996 Infiniti Q45
isnt the preferred offset closer to 35-40?
Rex
Car: None
qship96 wrote:isnt the preferred offset closer to 35-40?
Offset can't be discussed without referencing the wheel width at the same time, the 2 go hand in hand, that said the Y33 requires a lower offset on a similar width wheel than the G50.
