You cut it open and examined it under magnification like Q45tech? I am impressed! Of course that filter would not work so well now, eh?bullittandy wrote: The material inside the filter was limited.
Also, just to be provocative I'll also add that I reused not only the pan bolts, but also the gasket!! I did smear some non-hardening gasket maker on the gasket though.
I did cut it open and hopefully Wes will be able to put pics up soon.maxnix wrote:You cut it open and examined it under magnification like Q45tech? I am impressed! Of course that filter would not work so well now, eh?
"Member's standards vary." - Q45tech
