KingKarl »
https://forums.nicoclub.com/kingkarl-u27127.html
Sun Jun 12, 2005 2:57 pm
Thanks to NICO members I've finished all but hooking the hoses to the B&M ATF cooler. You guys really made it a snap...Falk was right on with the line along the front of the pan advice and I would have dropped the brass washer for sure had he not given me the "heads up". Pan was not bad but the magnet looked like a black doughnut with a jelly-like substance sticking to it. And Wes, my hair is caked with Mobil 1 ATF and I smell like an AAMCO sales rep.
After a great deal of taking things apart and looking I did the Maxnix ATF cooler install in front of the wheel well on the driver's side.... lots of space and seems like there will be lots of air moving through the openings under the grill/headlights and louvered well cover.
One last question...which side...driver's or passenger's side of the radiator, does the ATF return line back to the transmission exit on my 1998 Q45t? If some kind member will help, I can finish up this evening!
Again, thanks to all except the Iron Swede.
