Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Aug 06, 2007 10:33 am
They were not USED SUBFRAMES they were brand new subframes of which we have 1 left................nearly impossible to find in US.
Subframes with silicone filled isolators have a limited life, many fail after 10-12 years, depending on local conditions.............. and the amount of protective maintenance [Wurth Rubber Care] to keep them from cracking and splilling their goo.
Usually the mounting tabs and the frame itself bend, changing alignment,,,,,,,a 1/16th here and there is enough. I found this out when I replaced mine along with new rear camber arms............suddenly back to perfect midpoints.
