I felt lucky and got the iridium, exact same design except the center electrode is smaller due to iridium being more durable, lasting longer and needing less material that can wear away. NGK also said that it takes 5000 less volts to fire this plug, does that mean that those extra 5000 volts are going to the tip of the plug?maxnix wrote:Well, the Iridiums were available back then, but they neither were specified nor recommended by Nissan. Don't know why, but they probably do.
The Laser Plats work so perfectly, why change?
Unless you're feeling lucky.
qship96 wrote:sell those extra 5000 volts back to your local power company!
What do you mean "how long it sparks"?maxnix wrote:
It's not just spark, but also how long it sparks. Nissan had access to any type of plug when they designed the engine. They specified the ones that worked best.
