I did the knock sensors a few years ago and used new gaskets but there was one vacuum line I had to tee because I couldn't find the spot on the intake manifold. Fast forward to today and I used a smoke machine to find it! I did not see smoke coming out anywhere else however I realize gaskets can fail where it might not be obvious.
Anyways, this is for my 2000 Q. I do have an aftermarket cold air (filter sits in the fender well)
Idle after warming up
Short term -20-25%
Long term 6-7%
I've read that fuel trims should be as close to 0 as possible so with that said it seems like I have a vacuum leak still present. Hence the high negative STF values.
As far as the long term, could it be the intake affecting that? That value seems a tad high but still within spec. Fair?
I've also checked (with the same code reader) the voltages on the four 02 sensors and they are good.
