qship96 wrote:start with a 4 tire rotation and precision balance.
Q-thanks for the advice, but I just had this done with a relatively new set of tires less than 5k ago, and the rumble was the same before and after.
Andy, my problem sounds 100% identical to yours. Let me know what happens if you do the mount/hangers first, and I will do the same. You nailed it on the head when you say cold Andy, when first started the rumbling can be VERY bad....goes away greatly once warmed up.
Wes, I'd like to rule out the driveshaft as this occurs in no other rpm in any other gear. If it was the driveshaft, I could keep it in first and theoretically recreate the rumble in any gear. Also, I should clarify-there is no "noise" that could change during different rpms's....it's really just a RUMBLE that can be felt and not heard.
