Y33 rough start
DriftingJesus
Hi everyone
After searching and not being able to find anything I decided to post this up. Any help is appreciated
I have a 2000 Q45 80,000 miles
Today I had a biatch of a time starting the car the engine would turnover and stumble, after two goes at it I started to pulse on the gas and it reluctantly started up.
It runs fine and it was smooth all the way to work although for the past month or so it has seemed a little jumpy between shifts. I took it on a blast down the street not wot but I got the revs decently high and it ran smoothly no hesitation. Also the idle when stopped at lights was fine. Now I’m wonder whether the girl will start up when I get out of work
What do you guys think, injector, filter?
qship96
Car: 1996 Infiniti Q45
We could guess all day long, or you could confirm the problem by investing in 1 hour of a professional Infiniti trained technicians time.
DriftingJesus
I'd rather not, thats why I posted this on a forum and didn't instead make a call to schedule an appointment to the nearest infiniti dealership.
Thanks anyways
fixer
Car: 08 Sentra
sometimes if the throttle body is gummed up it will close off the opening for ait to pass through, this will cause a very rich start. sometimes it will flood the engine. the best way to start a flooded engine is to floor it and crank it for 2 min at a time until it starts. you can get a fuel induction service done and that will prevent hard starts. i noticed that the y33 model throttle gets sticky when you first press on the accel pedal and that is from a gummed up throttle plate. if the throttle plates on your veh are clean then look elsewhere.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
qship96 wrote:We could guess all day long, or you could confirm the problem by investing in 1 hour of a professional Infiniti trained technicians time.
What in THE h*ll are you doing on an online forum for then?!?!?
To offer a real answer, it sounds like the car was flooded. If it doesn't happen again then that was probably it. The owners manual has a whole section devoted to starting a flooded engine which surprised me because I didn't think it was possible to flood an injected engine-weird huh?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You tell us!
Frequency of BG44K? Frequency of OEM filter change interval? Proper OEM specified sparkplugs? Tier 1 Premium? ISO-Heet? Any codes thrown? Gas in oil?
