bigblue wrote:I am trying to remove the front struts on my 1997 q45 and have everything off for the exception of the lower ball joint. I was able to get a 2 jaw puller on tie rod end to pop that off but cannot clear the strut to use a puller to pop off the lower ball joint. I don't want to kill the seal using a pickle fork. Must I leave it on and remove the control arm as well can somebody offer a trick? Thanks
Jack up the control arm slightly and slip a jack stand under the knuckle. Back off the ball joint nut even with the ball joint threads, as you appear to have done from the photo.
I use a heavy BRASS MAUL short handle. Give a good whack on the nut and she should slip/fall out. If not, repeat.
Good luck. Jack
