qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Tue May 19, 2009 12:46 pm
Did you check the CSF Radiator site? I would go with the aluminum core plastic tank model myself- same as what originally came from the factory- it lasted 10 years, which is excellent!
Even IF a All Metal radiator could be found, it is no guarantee it would last any longer, and not sure you would even WANT it to, as even an old NON leaking radiator needs periodic replacement due to interior blockage and external fin wear and dirt accumulation.
