q45omg wrote:a classic trick if the filter is stuck on, hammer a long screwdriver through it and turn it like a t handle. this is assuming you are unable to get it loose with a socket and a oil filter wrench, if i am understanding your post correctly?
Ok, I am a freaking jack**s. I will admit that.
I could easily reach the filter with my hand once I look around a bit. I had to use the hammer trick and it came of just fine.
For future reference for other newbie Q owners: for Y33 oil filter - you don't need to take anything like the air box etc. off the car. Just make sure the engine is cool, take off the plastic engine guard from the bottom and your hand will be able to reach the filter. Use a cap wrench as Wes said. It works very well.
Thanks a lot guys for your help.. Appreciate it as always.
