I need layman's terms lol.Q45tech wrote:Remember warmed up idle is always on the absolute verge of dying.........producing ZERO extra HP/torque otherwise the rpms would progressively increase........just enough torque to rotate engine.
A dirty spark plug or intake valve/runner or injector..........one coil with slightly lower voltage.
Correlating the different sound [from exhaust pipe] with the sequential cylinder making it tells you the problem cylinder..............how many milliseconds from spark plug firing until the exhaust sound gets to rear.
All about quality expensive test equipment, just as it is with measuring frequency of vibrations in body
I can't believe that you're respected here.Q45tech wrote:Please supply your Millers Analogy Score so I may develop a course that suits your Intelligence.
What is a layman, someone without a Masters degree in Physics or someone who made B's in a 4 year liberal arts college with poor standards.
Tech, how would an exhaust leak affect this test? I'm sure that many of the Q's that are experiencing this stumble, are higher mileage and likely to have exhaust leaks.Q45tech wrote:I was being serious and not mean since there are more exotic methods than the simple acoustic timing method but they require much more expensive test equipment than the ~~ $3,000 unit with software suggested.
Those with a laptop or a computer with a sound card can download free acoustic sprectrum analyser software or oscilloscope software and use that to record the exhaust soundtrack and view the misfire sound.
Sample an injector or coil voltage to identify cylinder number #1
http://freenet-homepage.de/dl4yhf/spectra1.html
http://www.bestfreewaredownloa....html
http://www.electronics-lab.com....html
Wooh, someone is acting their shoe size again. Did someone forget to take their metamucil? I was being sarcastic. Remember, I didn't ask the original question. I'm a electrical engineer who graduated from a great school so please route your asinine remarks to some of your fellow co-workers who probably will faint at the tought of solving an engineering equation! Keep coaching and giving them valuable information so I can pay them to work on my car!Q45tech wrote:Please supply your Millers Analogy Score so I may develop a course that suits your Intelligence.
Well, for that plug, you may have found a problem, but what is the cause?bullittandy wrote:I have a possible clue!!! I'm also replacing spark plugs at this time and one plug has black sooty chunks on it-maybe the cylinder that was misfiring? I'm going to check the driver's side later and report back.
Similar symptoms may have different causes.bullittandy wrote:....since this problem still does not have a solution.
Read the code, switch the coil, follow the code.bullittandy wrote:I feel pretty confident that the idle stumble on the 97+ cars is a coil problem and once we find an easy way to discover the bad coil then life will be great again!!
