Y33 possible oil change problem
RAQ45t
Car: 1997 Infiniti Q45t
My '97 Q45t has always had dealer-serviced oil changes for its 162k life. Today,while having other work done at an indepentant shop,they put in 10-30 pure synthetic oil,rather then the Castrol blended 5-30 the dealer here uses. In the past(with BMWs),any car with high mileage changed from mineral based to synthetic oil had a good chance of delevoping engine seal leaks from the thinner,more efficient(at cleaning) oil. Will the change from blended to pure synthetic possibly lead to seal leaks in the Q,or am I just too paranoid?
NightRiderQ45
Car: 1998 Infiniti Q45
RAQ45t wrote: My '97 Q45t has always had dealer-serviced oil changes for its 162k life. Today,while having other work done at an indepentant shop,they put in 10-30 pure synthetic oil,rather then the Castrol blended 5-30 the dealer here uses. In the past(with BMWs),any car with high mileage changed from mineral based to synthetic oil had a good chance of delevoping engine seal leaks from the thinner,more efficient(at cleaning) oil. Will the change from blended to pure synthetic possibly lead to seal leaks in the Q,or am I just too paranoid?
I think this is a case by case situation. The full synthetic will clean out the crud in the engine and oil will probably seep thru the old VC/seal gaskets. That's what happened to my car. My vc never leaked until I put full synthetic oil in my car. I went back to dino oil, but they are still leaking. I fixed the vc on the passenger side, just haven't done the driver's side yet. Once you start to smell oil hitting the hot exaust, then you will know for sure.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I think you are fine, and no worry about leaks.
I really thought the M1 5W-30 was not right for the VH, and run 10W-30 M1 predominantly.
NightRiderQ45
maxnix wrote:I think you are fine, and no worry about leaks.
Why do you say that? I'm running 5w 30 dino now.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Just seemd a little thin even in Seattle winters. It seems to be a different formulation thatn the 10W-30.
I always ran at least 5 qts. of 10W-30 with it.
RAQ45t
Thanks for the help;seems they're going from the 5-30 Castrol blended to pure synthetic won't require me to promptly remove it to prevent leakage..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Leakage should not be a problem. High temperatures in summer operation might be.
RAQ45t
High temperatures? No problem here I hope. Hits about 80 degrees here S.Fla.in the winter
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Not winter, summer.
RAQ45t
Thanks again for your help..the last was kind of an LOL statement.
After 10 years down here,anything less than 60 degrees seems downright cold.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yeah, I see parkas, gloves and scaves on the panhandlers when its 70 here. Total crack up.
