elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed Dec 27, 2006 6:08 pm
A reasonable mistake, I did that the first time too when doing the diagnosis on a Y33... Its weird having OBD port and consult port..
Anyway, the slip and TCS light doesnt really tell us much of anything, however its telling us that something is in fail safe (restating the obvious)... Kind of stupid it would throw the CEL and slip/TCS lights for engine related failsafe status!
Ideally what youd like to do is put in a data monitor and log all of the engine parameter when it starts doing it ... that way we can tell whats going on by comparing as read voltages with what is normal.
However, we can try things that dont cost anything for sort of a trial and error helps rule out the annoying stuff. I would try cleaning the CAS connector making sure theres no corrosion or anything. Might as well try it.. I always recommend people doing things from easy to hard regardless of if they may do anything.... it may fix it, it may not but at least we can rule it out if it doesnt do anything....
Since this is an intermittant problem, im inclined to think its not a coil because that would be a more permanent failure, and thers no failsafe regarding ignition coils, they just die and throw a CEL! If the ECU is in failsafe mode, that means its a major sensor thats failed (CAS, MAF, Temp, etc), and since the CAS is the only one having to do with the ignition circuit, seems like we have our culprit.
ive never heard of a CAS going on a Y33 however Im sure you'd be honored to be number 1!!!
