my12by60 »
https://forums.nicoclub.com/my12by60-u258835.html
Mon Oct 30, 2017 5:27 pm
I did a good degrease a few days ago and have already seen a first drip on a clean piece of cardboard I put under the car. On the passenger side, the lowest bolt that holds on the timing cover has fresh oil on it. I don't see any fresh oil coming from above that bolt. The drip from that location lands on the power steering pump and runs down to a final low drip point on the bolt which is used to release tension on the power steering belt. I also saw oil on the oil pan bolt that is closest to the power steering pump. I don't see any oil coming from the oil pan gasket above that bolt. I am not totally sure if the bolt threads are leaking or if that bolt is catching some spray from the timing cover leak. The spinning of the power steering pulley might be flinging oil around the area.
The passenger side timing cover looks like it might be accessible after removal of the fan, one pulley, and the pulley bracket that attaches to the front of that timing cover. Is that wishful thinking? Or is the job much more major than that to reseal that passenger timing cover gasket, which looks like factory grey RTV to me?
