Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Jul 28, 2005 12:03 am
Appliance parts - AC shops have a foam evaporator spray cleaner that you use ......pull fan speed transistor heat sink to gain some limited access to the evaporator core. Fill the system full of foam, let soak and wash out with a tiny water hose ...........don't exeed limit of evap drain hose or you'll have a flood.
The correct thing would be to pull the evaporator [disassemble air box] and clean. Usually cause by not turning compressor off 60 seconds before engine off............Remember Legionaires disease and what caused it.
"Outbreaks of legionellosis have occurred after persons have breathed mists that come from a water source (e.g., air conditioning cooling towers, whirlpool spas, showers) contaminated with Legionella bacteria. Persons may be exposed to these mists in homes, workplaces, hospitals, or public places. Legionellosis is not passed from person to person, and there is no evidence of persons becoming infected from auto air conditioners or household window air-conditioning units."
However nothing is ever 100%.
