Y33 LED interior light kits
whabbahead9
Car: 1997 Q 23Xk
A friend of mine just installed a LED interior light kit in his '09 accord, now I'm aware that the accord is a bit more popular than the Y33 Q45, but i figure someone should make some sort of kit for my application. I've looked on eBay and Amazon with no real luck. If any one knows if there's a kit for sale somewhere or knows the all the bulb sizes and could help me out… that'd be great.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I am not aware that anyone makes a kit, but there are plenty of people here that have converted their stuff to LED's. I'd recommend doing some searching here. There's somewhere that probably lists all the bulbs for the car so you should be able to cross reference to LED easily.
whabbahead9
Car: 1997 Q 23Xk
I cannot find a list of the interior lights and my FSM isn't working at the moment. but i think i've figured out most of them from Rock Auto. does anyone know the bulb numbers for the 3 little lights in the overhead console and below the front door handles?
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Tons of aftermarket for the Y33. The Y33 has the most aftermarket support of all the Q. I bet you can find it out of japan using google translate
Overhead lamps
http://www.auto-acp2.com/cm_nissan/cima/elect.htm
whabbahead9
Car: 1997 Q 23Xk
BCC93QT wrote:Tons of aftermarket for the Y33. The Y33 has the most aftermarket support of all the Q. I bet you can find it out of japan using google translate
Overhead lamps
those are pretty pricey, my friend bought all of his for less than $30. why are these so expensive?
BCC93QT
1995 Infiniti Q45
Many variables. Quantity, quality, could be a closeout, could be a middleman, sourcing, Supply and demand?
Q451990
What are you trying to convert to LEDs? If you're not getting into the dash and controls, it should be pretty much plug-n-play. I have done this with my 90. Most everything is either 32mm festoon bulbs, or mini wedge of some sort. The lighting guide at http://www.sylvania.com is pretty accurate. Pictures of the lights you're talking about in the consoles and near the door handles would be helpful. They may not be listed if they're sold as part of an assembly from Nissan.
Heath
