Y33 knock sensor R&R question.
Levi
Car: 1998 Infiniti Q45
I am preparing to R&R the knock sensors on my 98 Q45. I understand the intake does not need to be removed but I have a few questions on the removal process. Are the knock sensors attached by two phillips screws? What is the best angle to remove the knock sensors? Do I need to remove any parts off the intake to gain access to them? Any tricks of the trade would be appreciated greatly. Thank You.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
haven't done the ks yet on my fy33. but i can tell you that they are held on by 12 mm head hex screws (not phillips).even if you don't *have* to remove the plenum, might want to anyway---will be a whole lot more accessible, and then you can clean the intake to spotless. change ALL the rubber while under there, then you wont go back under the plenum for another 100k+.also, was an ITB for the upper to lower plenum gasket leaking.
Levi
From my viewpoint it appears the easiest access to the KS's is through the back of the engine through the opening next to the transmission dipstick. I should be able to get a wrench or socket on the KS bolts. Does anyone have other suggestions on how to get to the knock sensors.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
I removed the fan, alternator and radiator as well as a couple of hoses and found them (K/S) accessible under the intake from the front of the engine. It really wasn't too hard and had few obstructions other than a coolanthose under the intake.
Good luck!!
bullittandy
Levi
Thanks for the information Bullittandy. I will update the post after I replace them.
00q45t47303
Car: 2000 Q45 Anniversary Edition
I replaced my knock sensors, harness, radiator hoses, clamps, etc. I think I have a small antifreeze leak. Did you use gasket maker on the knock senor bolts when you installed them?
Q45tech
CAREFUL the KS grounds thru the bolt and the metal at bottom of KS must be clean!!!!!!!!!!!!! as with the head area where it bolts to!!!!!!!!!!!!!!!!!!
00q45t47303
it was just a small amount of antifreeze. i blew it off the intake with compressed air. It's gone and hasn't came back. It must of just been left over from the install. Thanks for your help. Everything is working fine now.
bullittandy
Glad to hear of your success.
bdijanni
Car: 99 Infiniti Q45t fy33 88 Nissan 300zx z31
The best way to do it is through the front, But I didn't remove the radiator, or the fan!
