Y33 intermitten TCS (+ ABS) lights kickin in
Qproject
anyone have this occur on their y33 ?
when driving around 40-50mph, a slight stall then the TCS + ABS lights kick in.
It goes away when I restart my engine.
this is the 2nd time it has happened within the last 2 months.
any thoughts ?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Have you checked your alternator lately? BAttery too?
BTW, no Y33 ever imported to the states.
Qproject
battery and alternator look fine.
any other possibilities ?
maxnix wrote:Have you checked your alternator lately? BAttery too?
Chrisfrend
I had both lights go on intermittently for a few days and then they stayed on. I took my 97 Q to the dealer and told them the relevent fuses seemed OK but I couldn't be sure about the relays. After running $300 of diagnosis it turned out to be the ABS relay, which cost about $40 or so. They claimed the ABS relay was not responding to Consult, generating the high cost. You may want to check the ABS relay too. Good luck.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
your profile is not complete, but there was a recall on certain 1997 alternators.
